BT.com
Wishlist
TRENDnet Megapixel HD Wireless Day/Night PTZ Network Camera
TRENDnet Megapixel HD Wireless...
£119.66
Hurry, only 3 left in stock!
£119.66
Add to wishlist
Delivery
Standard 1-3 working days
The megapixel HD wireless day/night PTZ network camera, model TV-IP662WI, provides day and night monitoring over a large area. Pan and tilt the camera from a mobile device, record video to a Micro SD card, and have the camera email motion detection video clips. A wall/ceiling mounting kit is included and the camera's off white housing blends into most environments.
TRENDnet TV IP662WI Megapixel HD Wireless Day/Night PTZ Network Camera - network surveillance camera
Network surveillance camera - pan / tilt / zoom - outdoor
Audio
Yes: two-way audio capability, built-in microphone
10 cm x 11.3 cm x 12.8 cm
326 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/4" - 1 MP
Minimum Illumination
1 lux - colour , 0 lux - IR
Focal Length Control
Vari-focal
Focal Length
4.6 mm
Focus Adjustment
(min distance 20 cm)
Lens Iris
F/2.0
Panning Range (degree)
330
Tilting Range (degree)
115
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external - 1.8 m
Voltage
DC 12 V
White balance, saturation control, contrast control, e-mail alerts, image flip, image mirror, auto patrol, Motion Detection Technology, microSD card slot, Sound Detection Sensor, hue control, ONVIF V2.2 (Profile S) support, reset button
3 years warranty
Environmental Parameters (operating)
0 °C - 40 °C; 0 - 90% (non-condensing) relative humidity
Audio Support
Wired, wireless
10 cm
11.3 cm
12.8 cm
326 g
Camera
Colour - Day&Night - pan / tilt / zoom - outdoor
Digital Video Format
MPEG-4, H.264
Max Digital Video Resolution
1280 x 720
Digital Zoom
4
Exposure Range
1/3.75 sec - 1/15 sec
Video Capture
1280 x 720 @ 30 fps , 640 x 480 @ 30 fps
Still Image Capture Resolution
1280 x 720, 640 x 480
Image Sensor
1 MP CMOS 1/4"
Lens Construction
Vari-focal
Focal Length
4.6 mm
Lens Iris
F/2.0
Min Focus Distance
20 cm
Horizontal Field of View (degree)
49
Vertical Field of View (degree)
31
Panning
Range (degree)
330
Titling
Range (degree)
115
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, Bonjour, RTCP, PPPoE, Samba, 3GPP/ISMA, CIFS
Ports
LAN - RJ-45 , Audio line out - 3.5 mm jack
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - output - mini-phone 3.5 mm
Supported Memory Cards
microSD Card
Mounting bracket
1 x network cable - external - 1.8 m
Power Requirements
DC 12 V - 1 A
Power adapter - external AC 120/230 V (50/60 Hz) 10.5 Watt
Software Included
Drivers & Utilities, TRENDnetVIEW Pro
Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows 7 / Windows 8, Windows 8.1
Limited warranty - 3 years
Relative Humidity (operating)
Other bundles
TRENDnet Megapixel HD Wireless Day/Night PTZ Network...
£119.66
Kingston Gold microSD Card - Save 10%
Save £2.49
£134.14
Scroll to top
