BT.com
Wishlist
TRENDnet AC1750 Dual Band Wireless AC Router /w USB Port
TRENDnet AC1750 Dual Band Wireless...
£71.90
£71.90
Add to wishlist
Delivery
Standard Due date unavailable
TRENDnet's AC1750 Dual Band Wireless Router, model TEW-823DRU, is an extreme performance wireless router. It creates two concurrent wireless networks --a 1300 Mbps Wireless AC network and a 450 Mbps Wireless N network to connect common wireless devices. Use the USB port and Gigabit Ethernet ports to further expand your network.
Easy Setup
Get up and running in minutes with the intuitive guided setup
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
USB Share Port
Plug in a flash or storage drive into the USB port
Encrypted Wireless
For your convenience the router arrives pre-encrypted with its own unique password
Guest Network
Create an isolated network for guest internet access only
Parental Controls
Control access to specific websites or types of content
Next Generation Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home
Simultaneous Dual Band
High speed 1300 Mbps Wireless AC band + 450 Mbps Wireless N
Gigabit Ports
Gigabit ports extend high performance wired connections
Wireless Coverage
Whole home wireless coverage for average size homes
Backward Compatible
Compatible with legacy wireless devices
Targeted Beamforming
Increased real-time performance by directing stronger wireless signals to your specific location
Energy Savings
Embedded GREENnet technology reduces power consumption by up to 50%
TRENDnet TEW-823DRU - wireless router - 802.11a/b/g/n/ac (draft 2.0) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1300 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, DHCP, CSMA/CA, DDNS, DHCPv6
Routing Protocol
RIP-1, RIP-2, static IP routing
VoIP Protocols
H.323, SIP
Firewall protection, NAT support, Stateful Packet Inspection (SPI), ALG support, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, IP address filtering, GREENnet technology, firmware upgradable, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), Samba support, FTP server, reset button, pre-encrypted
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac (draft 2.0)
7.2 cm x 15.1 cm x 19.1 cm
408 g
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1300 Mbps
Selectable Channels Qty
13
Routing Protocol
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac (draft 2.0), FCC
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
IP Telephony
VoIP Protocols
H.323, SIP
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
6
External power adapter
18 Watt
1 x network cable - 1.5 m
Software Included
Drivers & Utilities
7.2 cm
15.1 cm
19.1 cm
408 g
Limited warranty - 3 years
0 - 95% (non-condensing)
Scroll to top
