BT.com
Wishlist
TRENDnet 8-Port Gigabit GREENnet Switch
Quality Steel Case 8 Port Gigabit Switch!
Delivery
Standard Due date unavailable
For the new version of this switch, click here
The compact 8-Port Gigabit GREENnet Switch provides high bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 70%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings.
Boost your office efficiency and eliminate network congestion with gigabit speeds and total switching capacity of 16Gbps with full-duplex mode. Plug and play this sturdy metal switch for reliable high-speed network connectivity.
TRENDnet TEG S80G - switch - 8 ports - desktop
Switch - 8 ports
Enclosure Type
Desktop
Ports
8 x 10/100/1000
MAC Address Table Size
4K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, GREENnet technology, Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
Environmental Standards
ENERGY STAR Qualified
17.1 cm x 9.8 cm x 2.8 cm
450 g
3 years warranty
Switch - 8 ports
Enclosure Type
Desktop
Ports
8 x 10/100/1000
4K entries
RAM
128 KB
Status Indicators
Link activity, port transmission speed, power
8 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Power adapter - external
Installed Qty
1
3.5 Watt
17.1 cm
9.8 cm
2.8 cm
450 g
Plug and Play, FCC, RoHS
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 - 90%
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Fast and Reliable
Reviewed by Anonymous on 28/03/2013
Bought this 11 months ago - plugged everything in and switched on - it's been running 24/7 since then - 0 issues. As fast as the old top of the range switch I had before, using 1/3 of the power. I put a lot of traffic through it daily from Xbox, Smart TV and several PC's, also put 8Tb through it when I upgraded the server - faultless.
5* Worked out of the Box
Reviewed by Steve on 25/09/2013
I can only echo the previous reviewer. It worked straight out the box, nothing to set up. No speed issues. Good construction with a metal case. Excellent value.
Scroll to top
