BT.com
Wishlist
TRENDnet 8-Port Cat. 5e Unshielded Patch Panel (10" wide)
TRENDnet 8-Port Cat. 5e Unshielded...
£12.76
More than 50 in stock
£12.76
Add to wishlist
Delivery
Standard 3-5 working days
The 8-port CAT 5e unshielded patch panel provides a 100MHz connection to 8 x Gigabit RJ-45 Ethernet ports. This 10-inch wide patch panel is well suited for home and SMB applications. A writing surface above each port allows users to label respective connections.
TRENDnet patch panel - 10"
Patch panel - CAT 5e - RJ-45 X 8
4.4 cm x 25.4 cm x 3 cm
205 g
Port Qty
8 ports
FCC, RoHS
2 years warranty
4.4 cm
25.4 cm
3 cm
205 g
Cabling & Wiring
Port Qty
8 ports
Termination Type
110 type termination, LSA (Krone)
Unshielded twisted pair (UTP)
Connector Provided
8 x RJ-45 female
Rack Size
10"
Weight Limit
7.7 kg
FCC, RoHS
2 years warranty
Service & Support Details
-10 °C
60 °C
Scroll to top
