BT.com
Wishlist
TRENDnet 8-Port 10/100Mbps PoE Switch
TRENDnet 8-Port 10/100Mbps PoE...
£48.61
4 in stock
£48.61
Add to wishlist
Delivery
Standard 3-5 working days
TPE-S44 Wireless PoE Access Point is today's link to Wireless Technology. Compliant with the IEEE Wireless Networking Standard 802.11g, it provides Direct Sequence Spread Spectrum (DSSS) operation for transparent bridging and roaming capabilities for wireless nodes. The TPE-S44 also provides WDS bridging functions, allowing users to connect two or more Access Points together, wirelessly. With this Wireless Access Point and Wireless Network Adapters, users can connect to Ethernet/Fast Ethernet LAN at home or office to access network resources with coverage up to 300 meters.
TRENDnet TPE-S44 - switch - 8 ports
Switch - 8 ports
Subtype
Fast Ethernet
Ports
4 x 10/100 (PoE) + 4 x 10/100
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 1.6 Gbps
MAC Address Table Size
1K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, PoE overcurrent protection, PoE circuit sorting protection
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
17.1 cm x 9.8 cm x 2.9 cm
430 g
3 years warranty
Bundled Services
3 years warranty
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
PoE
Performance
1K entries
Status Indicators
Port status, power, link/activity
4 x 100Base-TX - RJ-45 , 4 x 100Base-TX - RJ-45 - PoE - 15.4 W
External power adapter
36.3 Watt
FCC
17.1 cm
9.8 cm
2.9 cm
430 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Scroll to top
