BT.com
Wishlist
TRENDnet 8-port 10/100Mbps PoE+ Switch
TRENDnet 8-port 10/100Mbps PoE+...
£120.14
25 in stock
£120.14
Add to wishlist
Delivery
Standard 1-3 working days
The 8-port 10/100 Mbps PoE+ switch, model TPE-T80H, delivers data and power over existing Ethernet cables to Power over Ethernet (PoE) devices such as access points and IP cameras. It supplies up to 30 Watts of power per port with a 125 Watt power budget.
TRENDnet TPE T80H - switch - 8 ports - rack-mountable
Switch - 8 ports
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
125 W
Performance
Switching capacity: 1.6 Gbps , Forwarding performance (64-byte packet size): 1.19 Mpps
MAC Address Table Size
4K entries
Half duplex mode, full duplex mode, GREENnet technology, 1.25MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
26.3 cm x 16 cm x 4.4 cm
1.8 kg
3 years warranty
Bundled Services
3 years warranty
Switch - 8 ports
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE+)
PoE+
PoE Budget
125 W
Performance
4K entries
8 x 100Base-TX - RJ-45 - PoE+ - 30 W
Internal power supply
130 Watt
Rack Mounting Kit
Included
FCC
26.3 cm
16 cm
4.4 cm
1.8 kg
Limited warranty - 3 years
0 - 90% (non-condensing)
Other bundles
£120.14
Save on TP Link Smart Plug
Save £2.00
£144.11
Scroll to top
