Click to visit BT.com
BT.com
Wishlist
TRENDnet 500Mbps Powerline AV Ethernet Adapter
Quicklinx: 82QHWS00
Mfr#: TPL-401E
The powerline AV adapter, model TPL-401E, uses any electrical outlet to create a secure building-wide high speed network. Connect one adapter to your network and plug another adapter into any outlet on your electrical system for instant high speed network access. Connect adapters quickly using the convenient one-touch button.
TRENDnet TPL-401E - bridge - desktop
Bridge
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
128-bit encryption, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug AV
( 50 - 60 Hz )
7.2 cm x 9.8 cm
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions)
3 years warranty
Bridge
Enclosure Type
Desktop
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug AV , FCC
Built-in Devices
Led panel
Status Indicators
Link activity, power
Line Properties
Line Coding Format
BPSK, QPSK, OFDM, ROBO
1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV
External power adapter
( 50 - 60 Hz )
4.69 Watt
7.2 cm
9.8 cm
3 years warranty
Service & Support Details
Limited warranty - 3 years
0 - 90% (non-condensing)
