BT.com
Wishlist
TRENDnet 500Mbps Powerline AV Ethernet Adapter Kit /w Pass Through
Delivery
Standard Due date unavailable
The 500 Mbps Powerline AV Adapter Kit with Bonus Outlet TPL-402E2K uses any electrical outlet to create a secure building-wide high speed network. Connect one adapter to your network and plug the other adapter into any outlet on your electrical system for instant high speed network access.
Never lose an electrical outlet with the built in socket on the front of the adapter. A noise filter maintains optimum connection speeds when everyday household appliances such as toasters, washing machines, and coffee makers create electrical background noise.
A Gigabit Ethernet port maintains high performance wired connections. TRENDnet adapters auto connect when plugged in. Power save mode reduces power consumption. Advanced AES encryption secures your network. This adapter is ideal for use in buildings that interfere with wireless networking signals.
TRENDnet TPL-402E2K - bridge
Bridge
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Nodes: 64
Network / Transport Protocol
CSMA/CA
128-bit encryption, auto-uplink (auto MDI/MDI-X), full duplex mode, integrated power socket
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug AV, IEEE 1901
AC 120/230 V ( 50/60 Hz )
5.5 cm x 12.2 cm
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
3 years warranty
Bridge
Wired
Data Transfer Rate
500 Mbps
Max Range Indoors
300 m
Nodes: 64
CSMA/CA
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug AV, IEEE 1901 , FCC, RoHS
Status Indicators
Link activity, power
Line Properties
Line Coding Format
8 QAM, 64 QAM, 256 QAM, BPSK, QPSK, OFDM, ROBO, 1024 QAM
1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV
Internal power supply
Installed Qty
1
5 Watt
500 Mbps Powerline AV network adapter
2 x network cable - 1.5 m
Software Included
Drivers & Utilities
5.5 cm
12.2 cm
Limited warranty - 3 years
0 - 90% (non-condensing)
Scroll to top
