BT.com
Wishlist
TRENDnet 5-Port Gigabit GREENnet Switch
TRENDnet 5-Port Gigabit GREENnet...
£25.10
Quality Steel Case 5 Port Gigabit Switch!
More than 50 in stock
£25.10
Add to wishlist
Delivery
Standard 3-5 working days
The compact 5-Port Gigabit GREENnet Switch provides high bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 70%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings.
Boost your office efficiency and eliminate network congestion with gigabit speeds and total switching capacity of 10Gbps with full-duplex mode. Plug and play this sturdy metal switch for reliable high-speed network connectivity.
TRENDnet TEG S50G - switch - 5 ports - desktop
Switch - 5 ports
Enclosure Type
Desktop
Ports
5 x 10/100/1000
MAC Address Table Size
4K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, GREENnet technology, Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
Environmental Standards
ENERGY STAR Qualified
17.1 cm x 9.8 cm x 2.8 cm
430 g
3 years warranty
Switch - 5 ports
Enclosure Type
Desktop
Ports
5 x 10/100/1000
4K entries
RAM
104 KB
Status Indicators
Link activity, port transmission speed, power
5 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Power adapter - external
Installed Qty
1
3.67 Watt
17.1 cm
9.8 cm
2.8 cm
430 g
Plug and Play, FCC, RoHS
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 - 90%
Other bundles
£25.10
Save on TP Link Smart Plug
Save £2.00
£49.07
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great little switch
Reviewed by Anonymous on 29/05/2013
Metal case is a great feature, no chance of any interference, abslolute steal at this price and with a dsicount - works straight out the box, no external PSU either! best switch i've seen
5* Top quality and a doddle to set up
Reviewed by Anonymous on 29/07/2013
Firstly, I bought mine from the BT outlet store in ebay at the same price but with free delivery. It was delivered in two days which is fantastic. The switch itself is excellent and was simple to set up. Just plugged in to the mains (there's no external power adapter block which is neat) and then connected to my network via Homeplug which I've had for years. Then connected Sky+, WD TV, etc. via separate ethernet cables. Simple. All working fine as well.
5* TRENDnet 5-Port Gigabit GREENnet Switch
Reviewed by Anonymous on 04/07/2013
Contrary to the other review a PSU is required and it comes in the form of a small transformer which powers the tiny switch.
You notice the word tiny above as this switch is really small about the size of a double cassette tape box. The tiny package works well and is literally plug and play. No drivers or any other software required. Mine is plugged in to a power line Ethernet network and the response is faster than my supposed 300mb wireless connection was.
Scroll to top
