Click to visit BT.com
BT.com
Wishlist
TRENDnet 5-Port Gigabit GREENnet Switch
Quality Steel Case 5 Port Gigabit Switch!
5.0*
Quicklinx: 82GCWS00
Mfr#: TEG-S50g
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
Standard delivery Delivered within 3-5 working days
More than 50 in stock
£25.38
The compact 5-Port Gigabit GREENnet Switch provides high bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 70%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings.
Boost your office efficiency and eliminate network congestion with gigabit speeds and total switching capacity of 10Gbps with full-duplex mode. Plug and play this sturdy metal switch for reliable high-speed network connectivity.
TRENDnet TEG S50G - switch - 5 ports - desktop
Switch - 5 ports
Enclosure Type
Desktop
Ports
5 x 10/100/1000
MAC Address Table Size
4K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, GREENnet technology, Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
Environmental Standards
ENERGY STAR Qualified
17.1 cm x 9.8 cm x 2.8 cm
430 g
3 years warranty
Switch - 5 ports
Enclosure Type
Desktop
Ports
5 x 10/100/1000
4K entries
RAM
104 KB
Status Indicators
Link activity, port transmission speed, power
5 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Power adapter - external
Installed Qty
1
3.67 Watt
17.1 cm
9.8 cm
2.8 cm
430 g
Plug and Play, FCC, RoHS
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 - 90%
TRENDnet 5-Port Gigabit GREENnet Switch Bundle deal on TRENDnet 5-Port Gigabit GREENnet Switch
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£35.37
Customer reviews
Write a review for the TRENDnet 5-Port Gigabit GREENnet Switch here!
Great little switch
Reviewed by Anonymous Review Posted 29/05/2013
Metal case is a great feature, no chance of any interference, abslolute steal at this price and with a dsicount - works straight out the box, no external PSU either! best switch i've seen
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Top quality and a doddle to set up
Reviewed by Anonymous Review Posted 29/07/2013
Firstly, I bought mine from the BT outlet store in ebay at the same price but with free delivery. It was delivered in two days which is fantastic. The switch itself is excellent and was simple to set up. Just plugged in to the mains (there's no external power adapter block which is neat) and then connected to my network via Homeplug which I've had for years. Then connected Sky+, WD TV, etc. via separate ethernet cables. Simple. All working fine as well.
  • Overall 5*
  • Ease of use 5*
Reviewed by Anonymous Review Posted 04/07/2013
Contrary to the other review a PSU is required and it comes in the form of a small transformer which powers the tiny switch.
You notice the word tiny above as this switch is really small about the size of a double cassette tape box. The tiny package works well and is literally plug and play. No drivers or any other software required. Mine is plugged in to a power line Ethernet network and the response is faster than my supposed 300mb wireless connection was.
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Ports: 5
Managed: No
Brand: TRENDnet
Price Range Inc VAT: 0 - 50
