BT.com
Wishlist
TRENDnet 5-Port 10/100Mbps GREENnet Switch
TRENDnet 5-Port 10/100Mbps GREENnet...
£20.14
3 in stock
£20.14
Add to wishlist
Delivery
Standard 3-5 working days
The compact 5-Port 10/100Mbps GREENnet Switch TE100-S50g provides improved bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 40%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management requirement.
Boost your office efficiency and reduce network congestion with a total switching capacity of 1Gbps with Full-Duplex Mode. Plug and Play this sturdy metal switch for reliable high-speed network connectivity.
TRENDnet TE100 S50g - switch - 5 ports
Switch - 5 ports
Subtype
Fast Ethernet
Ports
5 x 10/100
Performance
Forwarding performance: 1 Gbps
MAC Address Table Size
2K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, MAC address filtering, GREENnet technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
Environmental Standards
ENERGY STAR Qualified
11.6 cm x 7 cm x 2.4 cm
192 g
Apple MacOS, Linux, Microsoft Windows
3 years warranty
Bundled Services
3 years warranty
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
5 x 10/100
Performance
2K entries
RAM
128 KB
Status Indicators
Link activity, port transmission speed, power
5 x 100Base-TX - RJ-45
External power adapter
2.75 Watt
Plug and Play, FCC
11.6 cm
7 cm
2.4 cm
192 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Scroll to top
