BT.com
Wishlist
TRENDnet 5/7 dBi Outdoor Dual Band Omni Antenna Kit
TRENDnet 5/7 dBi Outdoor Dual Band...
£29.92
3 in stock
£29.92
Add to wishlist
Delivery
Standard 3-5 working days
This outdoor dual band omni antenna kit comes with a pair of high performance outdoor antennas which support 2.4 and 5 GHz radio transmissions. The omni-directional antennas provide blanket wireless coverage and have N-Type male connectors. The antennas work with 802.11ac/n/g/b/a routers and access points with N-Type female connectors.
TRENDnet TEW AO57 5/7 dBi Outdoor Dual Band Omni Antenna Kit - antenna
Antenna
Packaged Quantity
2 (specifications are for single item)
Indoor / Outdoor
Outdoor
2.2 cm 17.8 cm
58 g
Directivity
Omni-directional
Compatibility
802.11 a/b/g/n/ac
Frequency Range
2.4 - 2.5 GHz, 5.15 - 5.88 GHz
Gain
7 dBi (for 5 GHz), 5 dBi (for 2.4 GHz)
RoHS, WEEE
3 years warranty
Packaged Quantity
Antenna
Indoor / Outdoor
Outdoor
2.2 cm
17.8 cm
58 g
Aerial
Directivity
Omni-directional
Compatibility
802.11 a/b/g/n/ac
Frequency Range
Gain
Voltage Standing Wave Ratio (VSWR)
2:1
Horizontal Beamwidth
360°
Vertical Beamwidth
30°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x N connector male
RoHS, WEEE
Limited warranty - 3 years
-40 °C
70 °C
0 - 95% (non-condensing)
Scroll to top
