BT.com
Wishlist
TRENDnet 450Mbps Concurrent Dual Band Wireless N Router
Delivery
Standard Due date unavailable
TRENDnet's 450 Mbps Concurrent Dual Band Wireless N router, model TEW-692GR, is the first router to support 450 Mbps speeds on both the 2.4 GHz and 5 GHz bands at the same time. This router's raw horsepower redefines wireless networking as people know it, to easily stream HD video through the home.
Gigabit Wide Area Network and Local Area Network ports transfer wired data fast. Embedded GREENnet technology reduces port-based power consumption by up to 70%.
Advanced Multiple Input Multiple Output (MIMO) antenna technology reduces wireless dead spots. Wi-Fi Protected Setup (WPS) connects other WPS supported wireless adapters at the touch of a button. WMM Quality of Service (QoS) technology prioritizes gaming, Internet calls, and video streams. Assign up to four virtual networks on each wireless band and manage access control for IP addresses, website URLs, and data protocols.
TRENDnet TEW-692GR - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
Network / Transport Protocol
TCP/IP, PPTP, L2TP, PPPoE
Remote Management Protocol
HTTP
Firewall protection, DMZ port, NAT support, auto-uplink (auto MDI/MDI-X), ALG support, MAC address filtering, URL filtering, IP address filtering, GREENnet technology, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Multiple SSID support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, UPnP
15.5 cm x 16.3 cm x 2.6 cm
175 g
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
Selectable Channels Qty
165
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, UPnP , ETSI, FCC, RoHS
Status Indicators
Power, WAN, LAN, wireless
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable and internal
Antenna Qty
6
External power adapter
9.6 Watt
15.5 cm
16.3 cm
2.6 cm
175 g
Limited warranty - 3 years
0 - 90% (non-condensing)
Scroll to top
