BT.com
Wishlist
TRENDnet 300Mbps Wireless N USB Adapter
TRENDnet 300Mbps Wireless N USB...
£13.90
£13.90
Add to wishlist
Delivery
Standard Due date unavailable
This 300Mbps Wireless N USB 2.0 Adapter allows you to connect wirelessly with supercharged speed, range and reliability. Wireless speeds increase up to 300Mbps when connecting to TRENDnet Wireless N access points or wireless routers. This 802.11n device seamlessly connects to your wireless network without performance degradation.
TRENDnet TEW-624UB - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
2.7 cm x 8 cm x 1.2 cm
20 g
802.11b, 802.11g, 802.11n (draft)
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Microsoft Windows Vista / 2000 / XP
Microsoft Certification
Certified for Windows Vista
3 years warranty
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Frequency Band
2.4 GHz
Aerial
Antenna
Internal
Gain Level
3 dBi
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Plug and Play, FCC, RoHS
2.7 cm
8 cm
1.2 cm
20 g
Limited warranty - 3 years
10 - 95%
Scroll to top
