BT.com
Wishlist
TRENDnet 300Mbps Wireless N PoE Access Point
TRENDnet 300Mbps Wireless N PoE...
£40.56
£40.56
Add to wishlist
Delivery
Standard Due date unavailable
The N300 Wireless PoE Access Point (model TEW-653AP) combines high speed wireless n coverage with Power over Ethernet (PoE) technology* to deliver up to 12x the speed and 4x the coverage of wireless g**.
This feature rich device blends into most environments and offers Access Point, Wireless Distribution System (WDS), and Repeater mode functionality.
Define a weekly power saving schedule, view real time network traffic charts, turn off the flashing LED indicators, and assign individual VLANs* for up to 4 separate SSIDs. Advanced antenna technology (MIMO) delivers superior range and eliminates dead spots. Synchronize wireless clients at the touch of a button with Wi-Fi Protected Setup (WPS). Advanced encryption protects valuable data and WMM® Quality of Service (QoS) technology prioritizes video and audio packets.
*Optional power port and power adapter provided for non-PoE installations.
Maximum wireless signal rates are referenced from IEEE 802.11 theoretical specifications. Actual data throughput and coverage will vary depending on interference, network traffic, building materials and other conditions.
Virtual Local Area Networks (VLAN) created separately by Web Smart switches, Managed Layer 2 switches or third party
TRENDnet TEW TEW-653AP - radio access point
Radio access point
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
12 cm x 12 cm x 5 cm
280 g
3 years warranty
Radio access point
12 cm
12 cm
5 cm
280 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Status Indicators
Power, WLAN, LAN
VLAN support, auto-uplink (auto MDI/MDI-X), Wireless Distribution System (WDS) support, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Multiple SSID support, reset button
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
Antenna
Internal integrated
Antenna Qty
1
Gain Level
4 dBi
1 x 100Base-TX - RJ-45
Mounting Kit
Included
ETSI, FCC, RoHS
PoE
External power adapter
6 Watt
3 years warranty
Service & Support Details
Limited warranty - 3 years
45 °C
5 - 95% (non-condensing)
Scroll to top
