BT.com
Wishlist
TRENDnet 300Mbps Wireless N Gigabit Router
Delivery
Standard Due date unavailable
The 300Mbps Wireless N Gigabit Router offers unsurpassed wireless speed, coverage and reliability. Enjoy up to 14x the speed and 6x the coverage of a wireless g connection.
Gigabit Wide Area Network and Local Area Network ports transfer your data fast. Wi-Fi certification ensures optimal wireless throughput signal strength and compatibility.
Advanced Multiple Input Multiple Output (MIMO) antenna technology eliminates wireless dead spots. Wireless encryption and a manual on/off wireless switch keep your data safe. Wireless Protected Setup (WPS) integrates other WPS supported wireless adapters at the touch of a button. Seamlessly stream HD media, download files, surf and play games at wireless n Gigabit speed.
TRENDnet TEW-639GR - wireless router - 802.11b/g/n (draft 2.0) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE
Remote Management Protocol
HTTP
Firewall protection, DMZ port, IP-routing, NAT support, hardware encryption, VPN support, NAPT support, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), ALG support, dynamic DNS server, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, MIMO technology, virtual server support, Wi-Fi Protected Setup (WPS), IPSec passthrough
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0), UPnP
Environmental Standards
ENERGY STAR Qualified
16.3 cm x 15 cm x 2.6 cm
350 g
Microsoft Windows 95, Microsoft Windows 98, Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows NT, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
PPTP, L2TP, PPPoE
HTTP
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, PEAP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
MS-CHAP v.2, Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0), UPnP , FCC, RoHS
Status Indicators
Link activity, power
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
3
Gain Level
4 dBi
External power adapter
16.3 cm
15 cm
2.6 cm
350 g
Limited warranty - 3 years
0 - 90%
Scroll to top
