BT.com
Wishlist
TRENDnet 24-Port Gigabit GREENnet Desktop Switch
TRENDnet 24-Port Gigabit GREENnet...
£114.24
More than 50 in stock
£114.24
Add to wishlist
Delivery
Standard 1-3 working days
The 24-Port Gigabit GREENnet Switch, model TEG-S24Dg, provides high bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 70% .
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management requirement.
Boost office network efficiency and eliminate network congestion with Gigabit speeds and a total switching capacity of 48Gbps with full-duplex mode. A built in universal power supply reduces cable clutter and diagnostic LEDs help with network troubleshooting. Plug and Play this sturdy metal switch for reliable high-speed network connectivity.
TRENDnet TEG S24Dg - switch - 24 ports
Switch - 24 ports
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
Switching fabric bandwidth: 48 Gbps
MAC Address Table Size
8K entries
Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), packet filtering, store and forward, GREENnet technology, Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
28 cm x 18 cm x 4.4 cm
1.7 kg
3 years warranty
Bundled Services
3 years warranty
Switch - 24 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
8K entries
RAM
512 KB
Built-in Devices
Led panel
Status Indicators
Link activity, port transmission speed, power
24 x 1000Base-T - RJ-45
Internal power supply
13 Watt
1 x power cable
Plug and Play, FCC
28 cm
18 cm
4.4 cm
1.7 kg
Limited warranty - 3 years
0 - 90% (non-condensing)
Scroll to top
