BT.com
Wishlist
TRENDnet 16-port Gigabit GREENnet Rack Mount Switch
TRENDnet 16-port Gigabit GREENnet...
£75.24
9 in stock
£75.24
Add to wishlist
Delivery
Standard 3-5 working days
The 16-port Gigabit GREENnet Switch, model TEG-S16g, provides high bandwidth performance, ease of use, and reliability, all while reducing power consumption.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management requirement.
Boost office network efficiency and eliminate network congestion with Gigabit speeds and a total switching capacity of 32 Gbps with full-duplex mode. A built in universal power supply reduces cable clutter and diagnostic LEDs help with network troubleshooting. Plug and Play this sturdy metal switch for reliable high-speed network connectivity.
TRENDnet TEG S16g - switch - 16 ports - rack-mountable
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Switching capacity: 32 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-uplink (auto MDI/MDI-X), packet filtering, store and forward, half duplex mode, full duplex mode, GREENnet technology, Jumbo Frames support, port forwarding
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
44 cm x 14 cm x 4.5 cm
1.6 kg
3 years warranty
Bundled Services
3 years warranty
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Port transmission speed, power, link/activity
16 x 1000Base-T - RJ-45
Internal power supply
7.2 Watt
Rack Mounting Kit
Included
Plug and Play, FCC, RoHS
44 cm
14 cm
4.5 cm
1.6 kg
Limited warranty - 3 years
0 - 90% (non-condensing)
Scroll to top
