BT.com
Wishlist
TRENDnet 150Mbps Micro Wireless N USB Adapter
TRENDnet 150Mbps Micro Wireless N...
£11.70
34 in stock
£11.70
Add to wishlist
Delivery
Standard 3-5 working days
The 150Mbps micro wireless N USB adapter (model TEW-648UBM) quickly connects a laptop or desktop computer to a high speed wireless N network.
Enjoy proven wireless N speed and reliability, in a micro design that extends less than three eighths of an inch (9mm) from the edge of a computer. Connecting to a network is made easy with the external one-touch Wi-Fi Protected Setup (WPS) button. Advanced wireless encryption protects your valuable data. Wi-Fi Multimedia (WMM) Quality of Service (QoS) prioritizes important video, audio, and gaming traffic. Seamlessly stream video, download files, and play games with this ultra compact wireless n adapter.
USB 2.0 connector
Ultra compact form factor
Wi-Fi compliant with IEEE 802.11n standard
One-touch wireless connection with external Wi-Fi Protected Setup (WPS) button
Backwards compatible with IEEE 802.11g and IEEE 802.11b devices
Maximum reliability, throughput, and connectivity with automatic data rate switching
Supports 64/128-bit WEP, WPA/WPA2-RADIUS, and WPA-PSK/WPA2-PSK
Wi-Fi Multimedia (WMM) Quality of Service (QoS) data prioritization
Easy user setup and intuitive diagnostic utility
Coverage of up to 30 meters indoor (98 feet) and 50 meters outdoor (164 feet) *
3-year limited warranty
TRENDnet TEW-648UBM - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
2 cm x 0.7 cm x 1.5 cm
1 g
802.11b, 802.11g, 802.11n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions)
Microsoft Certification
Compatible with Windows 7
3 years warranty
Network adapter
External
USB 2.0
Wireless
Spread Spectrum Method
OFDM, DSSS
Data Transfer Rate
150 Mbps
Line Coding Format
OFDM
Frequency Band
2.4 GHz
Max Range Indoors
30 m
Max Range Open Space
100 m
Status Indicators
Link activity
Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
ETSI, FCC
Software Included
Drivers & Utilities
2 cm
0.7 cm
1.5 cm
1 g
Limited warranty - 3 years
0 - 95% (non-condensing)
Scroll to top
