BT.com
Wishlist
TRENDnet 1-Port Multi-Function Print Server (1 USB)
Delivery
Standard Due date unavailable
TRENDnet's 1-Port Multi-Function USB Print Server, model TE100-MFP1, transforms most stand-alone multi-function and standard USB printers into a shared network resource. Install your multifunction printer in the most ergonomic location and then connect the compact TE100-MFP1 to a wired network.
An intuitive utility provides a seamless user experience. Scan, fax, and print functionality from any networked workstation. This compact device fits into the smallest spaces.
TRENDnet TE100-MFP1 - print server
Print server
External
Interface (Bus) Type
USB
Ports
10/100 Ethernet
5.8 cm x 7.5 cm x 2.4 cm
60 g
10Mb LAN, 100Mb LAN
Bridged devices per station: 127
Network / Transport Protocol
TCP/IP, LPR/LPD, DHCP
IEEE 802.3, IEEE 802.3u, USB 1.1, USB 2.0, UPnP
Apple MacOS X 10.4, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X 10.7 Lion
3 years warranty
Print server
External
USB
Ports
10/100 Ethernet
Wired
10Mb LAN, 100Mb LAN
Status Indicators
Power, link/activity, USB
Auto-uplink (auto MDI/MDI-X), reset button, on/off switches, NetUSB support
1 x 100Base-TX - RJ-45
1 x USB 2.0 - 4 pin USB Type A
1 x network cable (external) - 1.5 m
FCC, RoHS
Power adapter - external
1.9 Watt
Software Included
Drivers & Utilities
5.8 cm
7.5 cm
2.4 cm
60 g
Limited warranty - 3 years
5 °C
0 - 90% (non-condensing)
Scroll to top
