BT.com
Wishlist
Transcend StoreJet 25M3 1TB Hard Drive USB 3.0/2.0
Delivery
Standard Due date unavailable
One plus one is greater than two. Transcend's StoreJet 25M3 portable hard drive combines the advantages of Transcend's shockproof StoreJet M series and the next-generation SuperSpeed transfer rates of USB 3.0, allowing users to enjoy ultra-fast file transfers and the high level of anti-shock protection.
Besides its outstanding combination of super fast transfer speeds and extra-rugged anti-shock design, the StoreJet 25M3 is equipped with an extremely convenient one touch auto-backup button. Now you can instantly backup, synchronize and copy large files without having to waste precious time waiting for the transfer to complete.
Transcend StoreJet 25M3 - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Buffer Size
8 MB
Spindle Speed
5400 rpm
One-Click backup button
Power Source
USB bus
8.2 cm x 13 cm x 2 cm
216 g
Microsoft Certification
Compatible with Windows 7
3 years warranty
1 TB
2.5"
USB 3.0
Internal Drive Interface
Serial ATA
Buffer Size
8 MB
8.2 cm
13 cm
2 cm
216 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Software Included
StoreJet Software
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7, Linux Kernel 2.6.31 or later
1 x USB 3.0 cable - external , 1 x USB power cable - external
Plug and Play, BSMI, FCC
Limited warranty - 3 years
5 °C
55 °C
Scroll to top
