BT.com
Wishlist
Transcend DrivePro 50 Dashcam inc 16Gb SD Card - Adhesive Mount
Delivery
Standard Due date unavailable
The DrivePro 50 is a car video recorder that does away with everything except the essentials. With exceptional picture quality and low-light performance, live streaming to devices, compact design, Transcend's DrivePro 50 has everything you need in a dash camera.
Transcend DrivePro 50 - dashboard camera
Dashboard camera - 1080p - widescreen
Memory Card Slot
microSD card
Sensors
G-sensor
Wireless Interface
Wi-Fi
Sensor Resolution
3.0 MP
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens f/1.8
Incident Detection
G-Sensor
Supported Battery
1 x Li-Polymer rechargeable battery - 470 mAh (included)
USB 2.0
5.5 cm x 3.135 cm x 5.8 cm
49 g
2 years warranty
Camcorder Sensor Resolution
3.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Sensors
G-sensor
Digital Video Format
H.264, MOV
1920 x 1080
USB 2.0, Wireless LAN
Connectivity Features
Remote control via mobile devices, remote live view
Lens System
Wide-angle lens f/1.8 - wide angle
Max View Angle
130 degree(s)
Additional Features
Low Lux / Night Mode
Additional Features
Audio recording, built-in speaker, auto power save
Dashboard Camera Features
Incident Detection
G-Sensor
Event Recording Mode
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0
Software
Software
Drivers & Utilities, Transcend DrivePro PC Tool
Car power adapter, adhesive mount
Details
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Included Memory Card
16 GB microSDHC
Memory Card Max Supported Size
64 GB
Video Capture
H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps
5.5 cm
3.135 cm
5.8 cm
49 g
-20 °C
65 °C
Scroll to top
