BT.com
Wishlist
TP LINK WLAN-Antenna 2.4GHz 8dBi Indoor with Cable
TP LINK WLAN-Antenna 2.4GHz 8dBi...
£9.73
25 in stock
£9.73
Add to wishlist
Delivery
Standard 3-5 working days
What This Product Does
Indoor desktop omni-directional antenna TL-ANT2408C operates in the 2.4-2.5 GHz band and provides 8dBi omni-directional operation, which largely extends the wireless range and delivers much better wireless performance. The antenna offers the RP-SMA Female connector guaranteeing wider compatibility with most of the wireless equipments.
Replacing your wifi antenna with TL-ANT2408C will significantly increase the range and strength of your wifi signal. This quality built omni-directional antenna is a direct replacement for the antenna that comes standard with your router, access point. Because it is omni-directional, no aiming is equired - it can send and receive wifi in all directions.
Easy To Use
Installation is very easy - just detach your device's factory antenna and attach our booster antenna and you'll experience an instant increase in signal coverage and stability. Please note that the increase in signal strength depends mostly on your router or adapter; upgrading the antennas helps but the signal cannot transmit or receive at a level that your modem or adapter does not have.
TP-LINK TL-ANT2408C - antenna
Antenna
Placing / Mounting
Desktop
Indoor / Outdoor
Indoor
Directivity
Omni-directional
Frequency Range
2.4 - 2.4835 GHz
Gain
8 dBi
RoHS
Antenna
Placing / Mounting
Desktop
Indoor / Outdoor
Indoor
Cable Length
1.3 m
Aerial
Directivity
Omni-directional
Frequency Range
2.4 - 2.4835 GHz
Gain
8 dBi
Voltage Standing Wave Ratio (VSWR)
1.92:1
Horizontal Beamwidth
360°
Vertical Beamwidth
15°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x RP-SMA male
Mounting magnet
RoHS
-10 °C
60 °C
10 - 90%
Scroll to top
