BT.com
Wishlist
TP LINK WLAN Antenna 2.4 GHz 9dBi Outdoor Yagi N-Connector
Delivery
Standard Due date unavailable
Directional Antenna TL-ANT2409B operates in the 2.4GHz band and provides 9dBi directional operation, which largely extends the wireless range and delivers much better wireless performance. The antenna offers the N female connector guaranteeing wider compatibility with most of the wireless equipment's. Also, the weather proof design ensures that it can work normally for various demanding outdoor solutions.
Enjoy the benefits of wireless connectivity at greater distances and throughput throughout your outdoor wireless zone. No configuration or installation software required.
Highlights:
* 9dBi directional operation provides extended point to point connection or indoor and outdoor area coverage
* Features 100cm CFD-200 low loss cable for flexible deployment
* N female connector, works with most of access points / wireless routers
* Provides easy installation mounting kits
Easy To Use
Installation of the TL-ANT2409B is simple and straight forward. It is compatible with most wireless devices (Access Points, Routers, Bridges and Network Adapters) on the market with removable external antennas.
Box Contains
9dBi Panel Directional Antenna
Installation mounting kits
User Guide
TP-Link TL-ANT2409B - antenna
Antenna
12 cm x 12 cm x 4 cm
Intended For
Wi-Fi
Aerial Placing / Mounting
Outdoor, wall-mountable, pole mount
Compatibility
802.11 b/g
Frequency Range
2.4 - 2.5 GHz
Gain
9 dBi
Directivity
Directional
FCC, RoHS
Antenna
12 cm
12 cm
4 cm
Cable Length
1 m
Aerial
Intended For
Wi-Fi
Compatibility
802.11 b/g
Frequency Range
2.4 - 2.5 GHz
Gain
9 dBi
Directivity
Directional
Voltage Standing Wave Ratio (VSWR)
1.92:1
Horizontal Beamwidth
60°
Vertical Beamwidth
75°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x N-Series connector female
FCC, RoHS
-10 °C
60 °C
10 - 90%
Scroll to top
