BT.com
Wishlist
TP LINK Wireless Print Server USB2.0
TP LINK Wireless Print Server...
£35.91
£35.91
Add to wishlist
Delivery
Standard Due date unavailable
Print servers give businesses the ability to streamline their printing requirements by taking commonly used printers, multifunction products, and all-in-ones, and connecting them to a network. This allows for more efficient printer management and more reliable performance of connected devices that require less maintenance thereby making printing problems, a less common occurrence.
TL-WPS510U is featuring functions that make users lives easier. The TL-WPS510U has come to a new level in technological excellence. With these functions and the addition of wireless capabilities, the TL-WPS510U gives your printers the power of flight!
TP-LINK TL-WPS510U - print server
Print server
External
Interface (Bus) Type
USB 2.0
6.5 cm x 4 cm x 1.9 cm
45 g
802.11b, 802.11g
Data Transfer Rate
54 Mbps
Network / Transport Protocol
TCP/IP, LPR/LPD
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g
Linux, Microsoft Windows 2000, Microsoft Windows XP, Apple MacOS X 10.2 or later, Microsoft Windows Vista, Microsoft Windows 2003
Print server
External
USB 2.0
Wireless
802.11b, 802.11g
Data Transfer Rate
54 Mbps
TCP/IP, LPR/LPD
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz
Status Indicators
Link activity, power
DHCP support, firmware upgradable
Aerial
Antenna
External detachable
Antenna Qty
1
Directivity
Omni-directional
Gain Level
1.8 dBi
1 x USB 2.0 - 4 pin USB Type B
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC
Power adapter - external
6.5 cm
4 cm
1.9 cm
45 g
50 °C
0 - 70%
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.70
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.20
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.14
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.52
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£37.98
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* Not worth it!
Reviewed by Steven Keyte on 14/09/2013
The set-up instructions are difficult to follow, not at all clear and after four hours of attempting to get this device to work I gave up, configuration was never saved to the print server so I never got to the stage of actually printing anything via this device. I have a reasonable knowledge of networking, using both Windows and Linux networks, but this device is difficult to set up, due to the poor instructions, the manufacturers website is of no help.
If you are looking for a 'plug and play' set-up, don't consider this unit.
1* Poor
Reviewed by D Miller on 17/12/2013
Very poor device. Manual rubbish and incompatible with many printers. Forget it and buy something else.
Scroll to top
