BT.com
Wishlist
TP LINK Wireless N Access Point
Delivery
Standard Due date unavailable
The TP-LINK Wireless N Access Point TL-WA901ND is designed to establish or expand a scalable high-speed wireless N network or to connect multiple Ethernet enabled devices such as game consoles, digital media adapters, printers, or network attached storage devices to a wireless network. The AP supports a host of different functions that makes your wireless networking experience more flexible than ever before. Now, you can enjoy a better Internet experience when downloading, gaming, video streaming or with any other application that you may wish to use.
TP-LINK TL-WA901ND Max Range 300Mbps Access Point - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
PoE injector
Power Over Ethernet (PoE) Supported
PoE
17.4 cm x 12 mm x 2.9 cm
Radio access point
17.4 cm
12 mm
2.9 cm
External
Wireless
Cable(s) / Media Type Supported
Ethernet 100Base-TX cable
Data Transfer Rate
450 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz
Status Indicators
Power, system, link/activity
Wireless Distribution System (WDS) support, MIMO technology, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode
Encryption Algorithm
WPA, WPA2
Authentication Method
Radio Service Set ID (SSID)
Aerial
Antenna
External detachable
Antenna Qty
3
Directivity
Omni-directional
Gain Level
4 dBi
1 x 100Base-TX - RJ-45
PoE injector
1 x network cable
PoE
External power adapter
-10 °C
10 - 90%
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.53
Scroll to top
