BT.com
Wishlist
TP LINK Wireless Ceiling Mount AP/WDS
Delivery
Standard Due date unavailable
EAP350 is a 300 Mbps wireless-n ceiling mount AP which offers users extended coverage, strong penetration, secure network management and simple connection.
It provides extended coverage and 3-floor penetration in your environment. MSSID and VLAN make your data more secure and easy management. Standard PoE interoperable with 802.3af makes Internet connection more flexible.
EAP350 designed as a ceiling mount AP which will not violate your interior decoration. EAP350 is the perfect choice for home and small business.
EnGenius EAP350 - radio access point
Radio access point
External
RAM
32 MB
Flash Memory
4 MB
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Virtual interfaces (VLANs): 4
Power Over Ethernet (PoE) Supported
PoE
12 cm x 12 cm x 5 cm
280 g
Radio access point
12 cm
12 cm
5 cm
280 g
Processor / Memory / Storage
RAM
32 MB
Flash Memory
4 MB
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM
Network / Transport Protocol
PPTP, L2TP, IPSec, DHCP
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, CLI
Frequency Band
2.4 GHz
Status Indicators
Power, status, WLAN, LAN
Power over Ethernet (PoE), VLAN support, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, MIMO technology, wall mountable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), DHCP server, Multiple SSID support
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA-Enterprise
Authentication Method
Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
1
Directivity
Omni-directional
Gain Level
5 dBi
1 x 1000Base-T - RJ-45
1 x network cable
Mounting Kit
Included
IC, FCC
PoE
External power adapter
50 °C
0 - 90% (non-condensing)
Scroll to top
