BT.com
Wishlist
TP LINK Wireless Ceiling Mount AP/WDS
Delivery
Standard Due date unavailable
Working in conjunction with 4ipnet WHG controllers, this 4ipnet access point extends business-class WLAN security and management capabilities in enterprise or industrial environments.
4ipnet EAP300 - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
22 cm x 12.7 cm x 3.3 cm
0.82 kg
Radio access point
22 cm
12.7 cm
3.3 cm
0.82 kg
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
DHCP, DNS
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP
Frequency Band
2.4 GHz, 5 GHz
Selectable Channels Qty
14
Status Indicators
Power, WLAN, LAN
DHCP support, power over Ethernet (PoE), VLAN support, repeating mode, Syslog support, DiffServ support, manageable, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, MIMO technology, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, wireless bridge mode
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, AES-CCMP, WPA2-PSK
Authentication Method
RADIUS, Extended Service Set ID (ESSID), Extensible Authentication Protocol (EAP)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.11f
Aerial
Antenna
External detachable
Antenna Qty
3
1 x 1000Base-T - RJ-45 , 1 x management - DB-9 , 1 x USB
FCC, RoHS, IEC 60529 IP50
PoE
External power adapter
-30 °C
70 °C
10 - 80% (non-condensing)
Scroll to top
