BT.com
Wishlist
TP LINK Wi-Fi Smart Plug with Energy Monitoring
TP LINK Wi-Fi Smart Plug with...
Free delivery
£39.99
Free delivery
Price Drop
Limited Time Offer
Usually £36.98!
23 in stock
£39.99
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Smart Control for A Smart Home
Easily Manage Your Home Electronics and Appliances Anytime, Anywhere
The Smart Plugs are easy to set up, and make it even easier to manage your household electronic devices anywhere in the world with a tap of your smartphone.
You're Always Home
Deter bad guys by setting your lights to turn on and off on a schedule so it seems like you're home when you are actually away.
Control and Automate without Getting Out of Bed
With a tap on your smartphone, you can easily turn off the lights and other devices in the living room without getting out of bed, or conveniently schedule all lights to go off by midnight.
Modern, Elegant, Simple
Inspired by a modern sensibility, the Smart Plug's design is both simple and elegant, allowing it to blend seamlessly with existing decor.
Never Leave Things Running
The Smart Plugs give you a peace of mind with the count down timer feature, which automatically switches off the running household appliances (clothes iron and curling iron) if you have set a time limit before.
Save Money When You Warm Up and Cool Off
You can efficiently conserve energy and save money while using the Smart Plugs to control your space heaters and fans. The Smart Plug tracks your device's power consumption in real-time, and has weekly and monthly summaries.
Compatible with Android, iOS and Amazon Echo
You can pair the Smart Plugs with Amazon Echo for voice control. And the free Kasa app lets you run them from any Android ( 4.1 and higher ) or iOS ( iOS 8 and higher ) smartphone.
TP-LINK HS110 - smart plug
Smart plug
Functions
Energy use monitor
Wireless - 802.11b/g/n
Supported Host Device OS
iOS, Android
6.63 cm x 7.7 cm x 10.03 cm
Smart plug
Functions
Energy use monitor
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
iOS, Android
Power scheduling
Power Provided
3.68 kW
RoHS, EAC
6.63 cm
7.7 cm
10.03 cm
131.8 g
5 - 90% (non-condensing)
Scroll to top
