BT.com
Wishlist
TP LINK TP-LINK MC200CM - fibre media converter - Gigabit Ethernet
TP LINK TP-LINK MC200CM - fibre...
£44.59
More than 50 in stock
£44.59
Add to wishlist
Delivery
Standard 3-5 working days
The MC200CM is a media converter designed to convert 1000BASE-SX fiber to 1000Base-T copper media or vice versa. Designed under IEEE802.3ab 1000Base-T and IEEE802.3z 1000Base-SX standards, the MC200CM is designed for use with multi-mode fiber cable utilizing the SC-Type connector. The MC200CM supports shortwave (SX) laser specification at a full wire speed forwarding rate. It works at 850nm on both transmitting and receiving data.
Other features of this module include the ability to be used as a stand alone device (no chassis required) or with TP-LINK's 19'system chassis, Auto MDI/MDI-X for TX port, and front panel status LEDs. The MC200CM will transmit at extended fiber optic distances utilizing multi-mode fiber up to 0.55 kilometers.
Fibre media converter - RJ-45 / SC multi-mode
External
Cabling Type
1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
Gigabit Ethernet
Max Transfer Distance
550 m
9.5 cm x 7.3 cm x 2.7 cm
P/N: TL-MC1400
External
Wired
Cabling Type
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Status Indicators
Power, receive, link/activity
Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode
IEEE 802.3z, IEEE 802.3ab, IEEE 802.3x
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-SX - SC multi-mode female x 2
FCC
External power adapter
9.5 cm
7.3 cm
2.7 cm
10 - 90%
P/N: TL-MC1400
Scroll to top
