BT.com
Wishlist
TP LINK TL-WR810N 300Mbps Mini Router
Delivery
Standard Due date unavailable
The compact size of the TL-WR810N means that you can put it in your pocket and take it with you, sharing Internet access wherever you go. The built-in adapter makes it perfect for travelers, students, and anyone else living life on the go. Ideal for home and travel use - to meet the wireless needs of almost any situation you might encounter, the TL-WR810N features Router, Range Extender, Client, and Access Point modes.
What's in the box
  • TP-LINK TL-WR810N
  • Network cable
TP-Link TL-WR810N - wireless router - 802.11b/g/n - wall-pluggable
Wireless router
Enclosure Type
Wall-pluggable
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing
Firewall protection, DMZ port, DHCP support, repeating mode, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, Access Point operational mode, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, virtual server support, wireless bridge mode, Wireless Client Mode, port triggering
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
8.5 cm x 7.5 cm x 2.8 cm
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Wireless router
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
Internal power supply
1 x network cable
8.5 cm
7.5 cm
2.8 cm
10 - 90% (non-condensing)
Scroll to top
