BT.com
Wishlist
TP LINK TL-PB2600 2600mAh Pocket-Sized Power Bank 5V USB
Delivery
Standard Due date unavailable
TL-PB2600 is a stand-alone power solution that ensures you never lose touch with your world on the move. TL-PB2600 relieves you from the endless anxiety of energy crisis.
TP-Link TL-PB2600 - power bank
Power bank
2.56 cm x 2.56 cm x 9.35 cm
68 g
Output Connector Type
USB - on cable: Micro-USB
2600 mAh
Cables
Micro-USB cable
Power bank
2.56 cm
2.56 cm
9.35 cm
68 g
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2.4 A
LED indicator
Voltage Provided
5 V
2600 mAh
Overcharge protection, overheat protection, short circuit protection, overdischarge protection, overcurrent protection, overvoltage protection
Micro-USB cable
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.08
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.50
£13.60
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.86
C2G USB 2.0 To Fast Ethernet Adapter
Quicklinx: 7BBC | In Stock
£22.72
Scroll to top
