BT.com
Wishlist
TP LINK TL-PA8030PKIT AV1200 3-Port Gigabit Passthrough Kit
TP LINK TL-PA8030PKIT AV1200 3-Port...
£86.17
14 in stock
£86.17
Add to wishlist
Delivery
Standard 3-5 working days
Using your home's existing electrical circuit, this TP-LINK TL-PA8030PKIT AV2 1200 3-Port HomePlug Starter Kit turns any electrical socket into an Internet connection. Simply plug into your wall socket and you are ready to enjoy HD streaming and gaming, no configuration required. You also won't lose a power socket with its integrated pass through socket included. With speeds of up to 1200Mbps for smooth Ultra HD streaming, online gaming or faster downloads, this TP-LINK TL-PA8030PKIT is a perfect solution for home entertainment.
Perfect for bandwidth demanding activities
With its advanced HomePlug AV2 technology, this TL-PA8030P KIT is introducing a HomePlug generation for even faster data transmission in the home network. The TP-LINK TL-PA8030PKIT supports 2x2 MIMO* with beamforming, so users benefit from ultra-fast data transfer speeds of up to 1200Mbps. Perfect for bandwidth demanding activities like streaming Ultra HD video to multiple devices simultaneously, online gaming and large file transfers.
3 Gigabit ports for maximum connectivity
With 3 Gigabit Ethernet ports, this TP-LINK TL-PA8030PKIT can simultaneously connect up to 3 wired-only devices. This makes the TP-LINK TL-PA8030PKIT the perfect home entertainment companion. Connect any 3 devices from smart TVs and games consoles to NAS boxes and computers to the Internet at the same time. Just plug the Ethernet cable into the HomePlug and away you go.
Extra power socket for additional devices
Where sockets are at a premium, the TP-LINK TL-PA8030PKIT with an integrated AC pass-through power socket, means the HomePlugs can be used like a traditional electrical socket. Plug your smart TV or games consoles into the HomePlug, as if it were a normal plug socket. No socket needs to go to waste. The built-in noise filter helps to prevent electrical signal noise from affecting HomePlug performance.
Plug and play, no configuration required
This TP-LINK TL-PA8030PKIT is easy to use as follows: 1. Plug a HomePlug adapter into a wall socket and connect it to the router, via an Ethernet cable. 2. Plug another HomePlug adapter into a wall socket in another room and connect it to your Internet enabled device via Ethernet - and you are done! The HomePlug adapters will automatically connect to extend your network. The 'Pair' buttons on the HomePlug adapters can also be utilised for securing or managing multiple HomePlug adapters in your home network.
Reduce power consumption by up to 85%
The TP-LINK TL-PA8030PKIT features a new-generation of HomePlug adapters, with its practical design and sophisticated Power-Saving Mode, will automatically switch from its regular "Working" mode to "Power-Saving" mode reducing its energy consumption by up to 85%.*
*Actual data will vary in different network conditions and environments.
High-speed data transfer rate of up to 1200Mbps
Ideal for Ultra HD streaming and online gaming
3 Gigabit ports create secure wired networks for PCs and smart TVs
Pass-Through makes power accessible to other devices
2×2 MIMO with beamforming ensures fast and stable connection
128-bit AES encryption ensures safe and secure network
Up to 300-meter range over the household power circuit
Power saving mode helps reducing power consumption by up to 85%
Compatible with all TP-LINK AV1200, AV1000, AV600, AV500 and AV200 adapters
Standard Warranty: 2-Years
TP-LINK TL-PA8030P KIT - Starter Kit - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0
Data Transfer Rate
1.2 Gbps
2T2R MIMO technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, IEEE 1901
AC 220 V (50 Hz)
13.1 cm x 7.2 cm x 4.2 cm
Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Windows 8
United Kingdom, Europe
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1.2 Gbps
Max Range Indoors
300 m
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, IEEE 1901, Plug and Play, RoHS
Status Indicators
Power, link/activity
Line Properties
Line Coding Format
OFDM
LAN: 1 x HomePlug AV , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 220 V (50 Hz)
6 Watt
1 x network cable - 2 m
Software Included
Drivers & Utilities
13.1 cm
7.2 cm
4.2 cm
10 - 90% (non-condensing)
Scroll to top
