TP LINK TL-PA4020KIT AV500 2-port Powerline Starter Kit
Standard Due date unavailable
TP-LINK's AV500 2-port Powerline Starter Kit, TL-PA4020 KIT, turns your existing powerline into a high speed network with no need for new wires or drilling. No configuration is required, simply plug your adapters into your power sockets and you can establish networking infrastructure in a flash. With a speed of up to 500Mbps, TL-PA4020 KIT transmits HD streaming and even 3D movies to every room, making it a great choice for an easy to build multimedia entertainment network.
Up to 500Mbps for up to 300 Meters
With advanced HomePlug AV technology, TL-PA4020 KIT provides users with stable, high-speed data transfer rates of up to 500Mbps on a line length of up to 300 meters. Together with its built-in AES encryption, the TL-PA4020 KIT is a great choice for a whole home solution to connect all network compatible devices, from computers and game consoles to set-top boxes for IPTV, printers and NAS hard drives.
HD Streaming
Up to 500Mbps powerline speed ensures smooth HD streaming.
Reduce Power Consumption by up to 85%
The TL-PA4020 KIT, a new-generation Powerline Adapters, with its practical design and sophisticated Power-Saving Mode consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce its energy consumption by up to 85%*.
*Actual data will vary because of the network conditions and environmental factors.
Plug and Play
You can set up a hassle-free powerline network within minutes with TP-LINK powerline adapters, just plug in and play. Also, the adapters' "Pair" buttons can be utilized for securing or managing multiple powerline adapters in your home powerline network.
*Note: Powerline adapters must be deployed in sets of two or more.
Support QoS for Advanced Multiple-media Optimization
The Quality of Service (QoS) function prioritizes the bandwidth requirements of data traffic. Users can choose which type of traffic they will use -- Internet, Online Game, Audio or Video, Voice over IP, and the QoS functions will guarantee clear, instant reproduction of that application, even when other applications are running on the network at the same time.
TP-LINK TL-PA4020KIT - bridge - wall-pluggable
Bridge - 2-port switch (integrated)
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
IEEE 802.3, IEEE 802.3u, HomePlug AV
6.3 cm x 4.7 cm x 4 cm
Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/8.1
Packaged Quantity
Enclosure Type
Data Transfer Rate
500 Mbps
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, Plug and Play, FCC, RoHS
Status Indicators
Power, LAN, link/activity
Line Properties
Line Coding Format
LAN: 2 x 10Base-T/100Base-TX - RJ-45 , LAN: 1 x HomePlug AV - power 2-pole
Internal power supply
2.18 Watt
1 x network cable - 2 m
Software Included
Drivers & Utilities
6.3 cm
4.7 cm
4 cm
10 - 90% (non-condensing)
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
Scroll to top
