BT.com
Wishlist
TP LINK TL-ANT5830B 5GHz 30dBi Outdoor Grid Parabolic Antenna 'N'
Delivery
Standard Due date unavailable
The TL-ANT5830B 5 GHz 30 dBi outdoor grid parabolic antenna is ideal for outdoor use by attaching to your wireless access points/routers which operate on less crowded 5 GHz band. It could be used for long distance point-to-point connection, providing your stable wireless links. It is very easy to use, no con­figuration or software installation required.
TP-LINK TL-ANT5830B - antenna
Antenna
90 cm 60 cm
Product Material
Die-cast aluminum
Intended For
Wi-Fi
Aerial Placing / Mounting
Outdoor, pole mount
Compatibility
802.11 a/b/g/n
Frequency Range
5.15 - 5.85 GHz
Gain
30 dBi
Directivity
Directional
RoHS, WEEE
Antenna
Product Material
Die-cast aluminum
90 cm
60 cm
Aerial
Intended For
Wi-Fi
Outdoor, pole mount
Compatibility
802.11 a/b/g/n
Frequency Range
5.15 - 5.85 GHz
Gain
30 dBi
Directivity
Directional
Voltage Standing Wave Ratio (VSWR)
1.8:1
Horizontal Beamwidth
Vertical Beamwidth
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x N-Series connector female
Mounting Kit
Included
Weatherproof
RoHS, WEEE
Scroll to top
