BT.com
Wishlist
TP LINK TL-ANT5823B 5GHz 23dBi Outdoor Panel Antenna 1M 'N' Connect
Delivery
Standard 3-5 working days
The TL-ANT5823B 5 GHz 23 dBi outdoor panel antenna is ideal for outdoor use by attaching to your wireless access points/routers which operate on less crowded 5 GHz band, It could be used for long distance point-to-point connection, providing your stable wireless links. It is very easy to use, no con­figuration or software installation required.
TP-LINK TL-ANT5823B - antenna
Antenna
Placing / Mounting
Pole mountable, wall mountable
Indoor / Outdoor
Outdoor
Directivity
Directional
Compatibility
802.11 a/n
Frequency Range
5.15 - 5.85 GHz
Gain
23 dBi
RoHS, WEEE
Antenna
Placing / Mounting
Indoor / Outdoor
Outdoor
Aerial
Directivity
Directional
Compatibility
802.11 a/n
Frequency Range
5.15 - 5.85 GHz
Gain
23 dBi
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x N connector female
Mounting Kit
Included
RoHS, WEEE
Scroll to top
