BT.com
Wishlist
TP LINK Smart Wi-Fi LED E27 Bulb with Colour Changing Hue
TP LINK Smart Wi-Fi LED E27 Bulb...
£49.45
More than 50 in stock
£49.45
Add to wishlist
Delivery
Standard 3-5 working days
Control your lighting from anywhere with the LB130. The smart bulb installs as easily as a standard light bulb, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa lets you manage your lights with your smartphone or tablet, including adjusting brightness, setting schedules and scenes, and tracking energy used. The LB130 can also change colour, with more than 16 million hues available to match any mood or occasion. For added convenience, you can control the LB130 with your voice when paired with amazon Alexa.
Highlights:
  • No Hub Required – Connect the bulb directly to your Wi-Fi at home
  • Manage Remotely – Control your lights from anywhere with your tablet or smartphone the free Kasa app (iOS, Android)
  • Colour Changing Hue – Fine-tune up to 16 million colours and adjust brightness as well as light appearance from soft white (2700k) to daylight (9000k)
  • Voice Control – Pair to Amazon Alexa and to enable voice control
  • Circadian Mode – Dynamically adjust light intensity and temperature to mimic natural light patterns
Package Contents:
  • Smart Wi-Fi LED Bulb LB130
  • Quick Installation Guide
TP-LINK LB130 - LED light bulb
Light Bulb Type
LED light bulb
Bulb Finish
Frosted
Wattage Equivalent
60 W
Colour of Illumination
16 million colours
Colour Temperature
2700-9000 K
Luminous Power
800 lumens
Dimmable
Light Bulb
LED light bulb
Bulb Finish
Frosted
Wattage Equivalent
60 W
16 million colours
Colour Temperature
2700-9000 K
Luminous Power
800 lumens
Dimmable
Android compatible, iOS compatible, Amazon Alexa compatible, Circadian mode, voice control, controlled via Wi-Fi
175 g
Resources
The following resources are available for the TP LINK Smart Wi-Fi LED E27 Bulb with Colour Changing Hue
  • Documentation
Scroll to top
