BT.com
Wishlist
TP LINK Smart Wi-Fi E27 LED Bulb with Tunable White Light
TP LINK Smart Wi-Fi E27 LED Bulb...
£65.04
£65.04
Add to wishlist
Delivery
Standard Due date unavailable
Control your lighting from anywhere with the LB120. The smart bulb installs as easily as a standard light bulb, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa lets you manage your lights with your smartphone or tablet, including adjusting brightness, setting schedules and scenes, and tracking energy used.
The LB120 also lets you tune its white temperature to create lighting suited to your mood, from bright daylight to soft, relaxing whites. For added convenience, you can control the LB120 with your voice when paired with Amazon Alexa.
Highlights:
  • Control your lights from anywhere with your tablet or smartphone using the free Kasa app (iOS, Android)
  • Dim brightness and fine-tune light appearance from soft white (2700k) to daylight (6500k)
  • Pair to Amazon Alexa and to enable voice control
  • Automatically matches light appearance to time of day
  • Track real-time energy used to stay informed
Package Contents:
  • Smart Wi-Fi LED Bulb LB120
  • Quick Installation Guide
TP-LINK LB120 - LED light bulb
Light Bulb Type
LED light bulb
Usage Modes
Anti burglar
Bulb Finish
Frosted
Socket Type
E26
Wattage
11 W
Wattage Equivalent
60 W
Colour of Illumination
Warm white/daylight
Colour Temperature
2700-6500 K
Luminous Power
800 lumens
Beam Angle
270 degree(s)
Dimmable
AC 120 V
Frequency Required
60 Hz
Usage Modes
Anti burglar
Light Bulb
LED light bulb
Bulb Finish
Frosted
Socket Type
E26
Wattage
11 W
Wattage Equivalent
60 W
Warm white/daylight
Colour Temperature
2700-6500 K
Colour Rendering Index
80
Luminous Power
800 lumens
Beam Angle
270 degree(s)
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible, Amazon Alexa compatible, Circadian mode, voice control, controlled via Wi-Fi
Power Requirements
AC 120 V
Frequency Required
60 Hz
UL, FCC, RoHS
175 g
-20 °C
Resources
The following resources are available for the TP LINK Smart Wi-Fi E27 LED Bulb with Tunable White Light
  • Documentation
Scroll to top
