BT.com
Wishlist
TP LINK Smart Wi-Fi E27 LED Bulb with Dimmable Light
TP LINK Smart Wi-Fi E27 LED Bulb...
£46.75
More than 50 in stock
£46.75
Add to wishlist
Delivery
Standard 3-5 working days
Control your lighting from anywhere with the LB110. The smart bulb installs as easily as a standard light bulb, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa also lets you manage your lights with your smartphone or tablet, including adjusting brightness, setting schedules and scenes, and tracking energy used. For added convenience, you can use your voice to control the LB110 when paired with Amazon Alexa.
Highlights:
  • Works with Amazon Alexa for voice control (Alexa device sold separately)
  • 60 Watt Equivalent, 2700K Soft White
  • Control your lights from anywhere with your tablet or smartphone using the free kasa app (Android 4.1 or higher / iOS 8 or higher)
  • Dim brightness to customize Lighting and suit your mood
  • Set schedules, timers, and countdowns and have your lights work around your life
  • No hub required; works with your Wi-Fi router
Package Contents:
  • Smart Wi-Fi LED Bulb LB110
  • Quick Installation Guide
TP-LINK LB110 - LED light bulb
Light Bulb Type
LED light bulb
Bulb Finish
Frosted
Socket Type
E26
Wattage
11 W
Wattage Equivalent
60 W
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
270 degree(s)
Dimmable
AC 120 V
Frequency Required
60 Hz
Light Bulb
LED light bulb
Bulb Finish
Frosted
Socket Type
E26
Wattage
11 W
Wattage Equivalent
60 W
Warm white light
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
800 lumens
Beam Angle
270 degree(s)
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible, Amazon Alexa compatible, voice control, controlled via Wi-Fi
Power Requirements
AC 120 V
Frequency Required
60 Hz
UL, FCC, RoHS
105 g
-20 °C
Resources
The following resources are available for the TP LINK Smart Wi-Fi E27 LED Bulb with Dimmable Light
  • Documentation
Scroll to top
