BT.com
Wishlist
TP LINK Single USB 2.0 Port Fast Ethernet Print Server
TP LINK Single USB 2.0 Port Fast...
£35.90
More than 50 in stock
£35.90
Add to wishlist
Delivery
Standard 3-5 working days
The TP-LINK TL-PS110U print server allows you to take the computer out of the loop while setting up a printing network. All that is needed is to connect the TL-PS110U to a printer via the USB port, connect the print server to your LAN, and you will be able to access your printer from any computer on the LAN.
TP-LINK TL-PS110U - print server
Print server
External
Interface (Bus) Type
USB 2.0
7.3 cm x 6.5 cm x 3 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Network / Transport Protocol
TCP/IP, IPX/SPX, AppleTalk, NetBEUI/NetBIOS, LPR/LPD, RAW, SMB
RAM
2 MB
IEEE 802.3, IEEE 802.3u, USB 2.0
UNIX, Novell NetWare 3.12 or later, Apple MacOS 8.0 or later, Linux, Microsoft Windows NT, Microsoft Windows 95/98/ME/2000/XP/Vista
Print server
External
USB 2.0
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Remote Management Protocol
SNMP, Telnet, IPP, HTTP
Status Indicators
Port status, port transmission speed, status
Auto-sensing per device, DHCP support, E-mail alert, firmware upgradable
Processor / Memory
RAM
2 MB
Flash Memory
1 MB
1 x USB 2.0 - 4 pin USB Type A , 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
FCC
7.3 cm
6.5 cm
3 cm
50 °C
0 - 70%
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.42
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.58
£15.04
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.94
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.76
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
