Click to visit BT.com
BT.com
Wishlist
TP LINK Single Parallel Port Fast Ethernet Print Server
Quicklinx: 8DHHWS00
Mfr#: TL-PS110P
Standard delivery Delivered within 3-5 working days
16 in stock
£28.87
The TP-LINK TL-PS110P print server allows you to take the computer out of the loop while setting up a printing network. All that is needed is to connect the TL-PS110P to a printer via the parallel port, connect the print server to your LAN, and you will be able to access your printer from any computer on the LAN.
TP-LINK TL-PS110P - print server
Print server
External
Interface (Bus) Type
Parallel
Ports
10/100 Ethernet
5.9 cm x 5.2 cm x 2.2 cm
10Mb LAN, 100Mb LAN
Network / Transport Protocol
TCP/IP, AppleTalk, NetBEUI/NetBIOS, IP/IPX, LPR/LPD, SMB
RAM
2 MB
IEEE 802.3, IEEE 802.3u
UNIX, Novell NetWare 3.12 or later, Apple MacOS 8.0 or later, Linux, Microsoft Windows Vista, Microsoft Windows NT / 2000 / XP / 2003
HP Color LaserJet 2500, 2500L, 2500Lse, 2500n, 2500tn, 2550n, 2605, 2605dn, 2605dtn, 3700, 3700d, 3700dn, 3700dtn, 3700n, 4500, 4500dn, 4500n, 4650, 4650dn, 4650dtn, 4650hdn, 4650n, 8550, 8550dn, 8550n; DesignJet 100, 600, 650c, 700, 750c; Deskjet 1120c
Print server
External
Parallel
Ports
10/100 Ethernet
Wired
10Mb LAN, 100Mb LAN
Remote Management Protocol
Telnet, HTTP
Status Indicators
Port transmission speed, status
DHCP support, manageable, E-mail alert, firmware upgradable
Processor / Memory
RAM
2 MB
Flash Memory
1 MB
1 x 100Base-TX - RJ-45
1 x parallel - IEEE 1284 (EPP/ECP) - 36 PIN Centronics
FCC
5.9 cm
5.2 cm
2.2 cm
50 °C
0 - 70%
HP Color LaserJet 2500, 2500L, 2500Lse, 2500n, 2500tn, 2550n, 2605, 2605dn, 2605dtn, 3700, 3700d, 3700dn, 3700dtn, 3700n, 4500, 4500dn, 4500n, 4650, 4650dn, 4650dtn, 4650hdn, 4650n, 8550, 8550dn, 8550n , HP DesignJet 100, 600, 650c, 700, 750c , HP Deskjet 1120c
TP LINK Single Parallel Port Fast Ethernet Print Server Bundle deal on TP LINK Single Parallel Port Fast Ethernet Print Server
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£38.86
8DHH C2G 2m DB9 Female to DB25 Male Modem Cable In Stock £5.32
8DHH C2G 2m IEEE-1284 DB25 M/M Parallel Cable In Stock £7.35
8DHH C2G 2m DB25 Male to Centronics 36 Male Parallel Printer Cable In Stock £5.58
8DHH C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £5.97
8DHH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.17
8DHH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.40
8DHH C2G 2m Cat6a Shielded Patch - Blue In Stock £8.92
8DHH C2G TruLink Media Gateway RJ45 Cap In Stock £0.70
8DHH C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £56.50
