BT.com
Wishlist
TP LINK Pigtail 3m Cable Length N-Type Male to RP-SMA Male
TP LINK Pigtail 3m Cable Length...
Clearance
£5.06
Clearance
While Stocks Last
Hurry, only 1 left in stock!
£5.06
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The TL-ANT24PT3 pigtail cable is ideal for flexible connection between rigid outdoor cable and wireless access points/routers. It is very easy to use, no configuration or installation software required.
TP-LINK TL-ANT24PT3 Pigtail Cable - antenna cable - 3 m
Antenna cable
Length
3 m
Connector
N-Series connector - male
Connector (Second End)
RP-SMA - male
Network Cable Type
Antenna cable
Impedance
50 Ohm
Length
3 m
Connector
RP-SMA - male
-10 °C
60 °C
Scroll to top
