BT.com
Wishlist
TP LINK PB5200 5200mAh Power Bank 5V USB Smart Charging LED
Delivery
Standard 3-5 working days
Housed in an ergonomically designed case, TL-PB5200 is a high capacity 5200mAh power bank compatible with most of your digital devices. With full capacity, the TL-PB5200 holds enough juice to fully charge your device once or even more times.
TP-Link TL-PB5200 - power bank
Power bank
5.35 cm x 2.2 cm x 9.27 cm
135 g
Output Connector Type
USB - on cable: Micro-USB
- 5200 mAh
Cables
Micro-USB cable
Power bank
5.35 cm
2.2 cm
9.27 cm
135 g
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2.4 A
LED indicator
Voltage Provided
5 V
5200 mAh
Overcharge protection, overheat protection, short circuit protection, overdischarge protection, overcurrent protection, overvoltage protection
Micro-USB cable
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.69
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.26
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.98
£14.65
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.55
C2G USB 2.0 To Fast Ethernet Adapter
Quicklinx: 7BBC | In Stock
£24.46
Scroll to top
