BT.com
Wishlist
TP LINK PB50 10000mAh Power Bank Dual 5V USB Smart Charge
Delivery
Standard Due date unavailable
PB50 comes equipped with a intelligent chip to recognize users device, and delivering the max-imum speed required, whether iOS, Android or other USB-enabled devices. The lithium polymer 10000 mAh battery is designed to provide users with a lighter, more powerful energy source that increases its portability and ensures that it continues working for you long after everyone else has gone home.
TP-Link PB50 - power bank Li-pol
Power bank
13.97 cm x 7.89 cm x 1.93 cm
281.3 g
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
Lithium polymer 10000 mAh
Cables
Micro-USB cable
Power bank
13.97 cm
7.89 cm
1.93 cm
281.3 g
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2 A
LED indicator, short circuit protection, overcharging protection, overheat protection, over voltage protection, over-current protection, overdischarging protection
Lithium polymer
10000 mAh
Max Recharge Cycles
500
Carrying pouch
Micro-USB cable
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.68
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.23
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.89
£14.59
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.55
C2G USB 2.0 To Fast Ethernet Adapter
Quicklinx: 7BBC | In Stock
£24.34
Scroll to top
