BT.com
Wishlist
TP LINK Dual Band N900 Concurrent Gigabit Router
Delivery
Standard Due date unavailable
Click Here to Claim a Free £10 iTunes Voucher Before June 30th 2013
TL-WDR4900 is a performance optimized simultaneous dual band wireless N router combining the blazing fast speeds of up to 450Mbps over the crystal clear 5GHz band and the traditional 2.4GHz band. With 900Mbps of total bandwidth, CPU Clock Speeds of up to 800MHz, 3 external antennas serving the 5GHz band, and 3 internal antennas serving the 2.4GHz band, you can run multiple bandwidth intensive applications in a large home or office. Simple tasks like sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band- all at the same time.
If you prefer a wired connection, the TL-WDR4900 boasts five gigabit ports and 900Mbps+ hardware NAT to provide a lightning-fast and lag-free experience. The two USB 2.0 ports will allow you to power a robust home Internet network by sharing printers, flash storage, ftp servers, or media players.
Impressive Speeds for Lag Free Entertainment
Simultaneous Dual Band - 2.4GHz up to 450Mbps + 5GHz up to 450Mbps
Two separate wireless networks that will run on either the 2.4GHz or 5GHz band, simultaneously. Did you know the 2.4GHz band gets interference from your neighboring networking devices, microwave ovens, cordless phones, or garage openers? The 5GHz band has 23 non-overlapping channels which is 8 times more than the traditional 2.4GHz band. Simultaneous Dual Band offers you the flexibility of two dedicated networks - with double the bandwidth for your needs.
Blazing Fast Wired Speed - 5 Gigabit Ports
With one gigabit WAN port and four gigabit LAN ports, speeds can be up to 10× faster than standard Ethernet connection. The TL-WDR4900 is powerful to support a robust and extremely fast wired network .
900Mbps+ Hardware NAT Speed
With built-in gigabit Ethernet switches and Hardware NAT function, the TL-WDR4900 is geared with powerful data processing capability. Its NAT WAN to LAN throughput can achieve up to 900Mbps+ speed to unleash the full potential of your network.
Leading Performance - CPU Clock Speed up to 800MHz
The powerful CPU can process data much faster with speeds of up to 800MHz, the foundation that drives this router's core performance. The 2.4GHz and 5GHz Wi-Fi chips are built independently to reduce CPU space and efficiently transmit Wireless signals. The NAT switch chip offers a faster NAT conversion rate and improves data forwarding rate, with NAT WAN to LAN throughput of up to 900Mbps.
3 External and 3 Internal Antennas
With 3 external 5dBi antennas serving the 5GHz band and 3 internal antennas serving the 2.4GHz band, the high quality antenna technology ensures high range across greater distance. This provides you with incredible wireless signal and coverage in any large home or office.
Dual Versatile USB Sharing Ports
With the two multi-functional USB 2.0 ports, you can share printers, files and media with different devices through your local network or via the ftp server while away from home.
IPv6 (Internet Protocol Version 6) Enabled
TL-WDR4900 supports IPv6 (Internet Protocol Version 6), the next generation of Internet protocol, helping you to future -proof your network.
Easy to Use
The Easy Setup Assistant found in the CD will help guide you through the setup process step by step. Whether you are looking to configure the wireless network or security options, it will be up and running in minutes. You may also setup the network security by simply pressing the "WPS" button. This automatically establishes a WPA2 secure connection and is more secure than WEP encryptions. Not only is WPA2 faster than normal security setup, you won't have to remember a password.
TP-LINK TL-WDR4900 - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
Routing Protocol
Static IP routing
DMZ port, NAT support, DoS attack prevention, manageable, print server, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, DHCP server, port triggering, Stateful Packet Inspection Firewall (SPIF), DHCP client
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP
24.3 cm x 16.06 cm x 3.25 cm
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Built-in Devices
Led panel
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Antenna: 3 x RP-SMA , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
Software Included
Drivers & Utilities
24.3 cm
16.06 cm
3.25 cm
Scroll to top
