Click to visit BT.com
BT.com
Wishlist
TP LINK Dual Band N600 Wireless Router
Quicklinx: 8BMGWS00
Mfr#: TL-WDR3500
TP-LINK's TL-WDR3500 is a performance optimized simultaneous dual band wireless router combining the blazing fast speeds of 300Mbps using the crystal clear 5GHz band and 300Mbps using the traditional 2.4GHz band. With simultaneous dual band, users have 600Mbps of total bandwidth to power numerous bandwidth intensive applications at the same time around a large home or office setting, where simple tasks such as e-mail or web browsing can be handled by the 2.4GHz band at 300Mbps and more latency sensitive tasks such as online gaming or HD video streaming can be processed over the 5GHz band at 300Mbps, at the same time, with USB 2.0 port capable of sharing flash storage, printers, ftp servers and media players, users can power a robust home media network.
5GHz 300Mbps + 2.4GHz 300Mbps - Concurrent Dual Band Wireless
The TL-WDR3500 broadcasts and receives both 2.4GHz and 5GHz connections simultaneously at 300Mbps and 300Mbps respective speeds. Like two wireless routers in one, this allows users to run day-to-day applications, such as e-mail and web browsing over the 2.4GHz band at 300Mbps while using bandwidth intensive or latency sensitive applications, such as streaming HD video or playing online games, over the clearer 5GHz band at 300Mbps, at the same time.
Versatile USB Sharing Port
Using the TL-WDR3500's multi-functional USB 2.0 port, users can share printers, files and media either throughout the network at home with several different computers or even away, using the device's ftp server functions so that you never have to part with your files.
IP QoS - Control Your Bandwidth
TL-WDR3500 supports IP QoS (Quality of Service), allowing optimum utilization of bandwidth and offering bandwidth control over congestion, preventing bandwidth abuse. In this way, users of a small network receive committed and specific bandwidth, preventing non-critical applications from degrading network performance.
One Button Security Setup
The TL-WDR3500 features Wi-Fi Protected Setup™ (WPS) that allows users to almost instantly setup their security simply by pressing the WPS button on the router and automatically establishing a WPA2 secure connection, which is more secure when compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that users needn't remember a password!
Easy To Use
The device comes with a CD featuring an Easy Setup Assistant that leads users through the setup process step-by-step, and even helps with wireless network settings and security configurations. With setups this easy, even novice users can have their networks up and running in mere minutes.
TP-LINK TL-WDR3500 - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
DMZ port, DoS attack prevention, dynamic DNS server, print server, MAC address filtering, Wireless Distribution System (WDS) support, parental control, IP address filtering, domain blocking, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, port forwarding, bandwidth control, port triggering, Stateful Packet Inspection Firewall (SPIF), dynamic IP mode, IP-MAC binding, on/off switches, DHCP client
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP
22.5 cm x 14 cm x 3.25 cm
UNIX, Apple MacOS, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz, 5 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP , IC, FCC, RoHS
Built-in Devices
Radio access point
LAN : 4 x 10Base-T/100Base-TX - RJ-45 , WAN : 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0 : 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
Software Included
Drivers & Utilities
22.5 cm
14 cm
3.25 cm
10 - 90% (non-condensing)
