BT.com
Wishlist
TP LINK Dual Band N600 concurrent Wireless Gigabit Router
Delivery
Standard Due date unavailable
TP-LINK's TL-WDR3600 is a performance optimized simultaneous dual band wireless router combining the blazing fast speeds of 300Mbps using the crystal clear 5GHz band and 300Mbps using the traditional 2.4GHz band.
With simultaneous dual band, users have 600Mbps of total bandwidth to power numerous bandwidth intensive applications at the same time around a large home or office setting, where simple tasks such as e-mail or web browsing can be handled by the 2.4GHz band at 300Mbps and more latency sensitive tasks such as online gaming or HD video streaming can be processed over the 5GHz band at 300Mbps, at the same time.
With five Gigabit ports and 800Mbps+ hardware NAT, your wired devices will have lightning-fast, lag-free connections and, in addition to 2 USB 2.0 ports capable of sharing flash storage, printers, ftp servers and media players, users can power a robust home media network.
5GHz 300Mbps + 2.4GHz 300Mbps - Concurrent Dual Band Wireless
The TL-WDR3600 broadcasts and receives both 2.4GHz and 5GHz connections simultaneously at 300Mbps and 300Mbps respective speeds. Like two wireless routers in one, this allows users to run day-to-day applications, such as e-mail and web browsing over the 2.4GHz band at 300Mbps while using bandwidth intensive or latency sensitive applications, such as streaming HD video or playing online games, over the clearer 5GHz band at 300Mbps, at the same time.
Versatile 2* USB Sharing Ports
Using the TL-WDR3600's two multi-functional USB 2.0 ports, users can share printers, files and media either throughout the network at home with several different computers or even away, using the device's ftp server functions so that you never have to part with your files.
Blazing Wired Speeds - 5 Gigabit Ports + 800Mbps Hardware NAT
With one Gigabit WAN port and four Gigabit LAN ports, the TL-WDR3600 is able to support a robust and extremely fast wired network, ideal for latency-sensitive applications such as HD media and online gaming. With built-in gigabit Ethernet switch and a Hardware NAT function, the wireless router provides powerful data processing capabilities. Its NAT WAN to LAN throughput can achieve up to 800Mbps+ allowing users to unleash the full potential of their networks.
IP QoS - Control Your Bandwidth
TL-WDR3600 supports IP QoS (Quality of Service), allowing optimum utilization of bandwidth and offering bandwidth control over congestion, preventing bandwidth abuse. In this way, users of a small network receive committed and specific bandwidth, preventing non-critical applications from degrading network performance.
One Button Security Setup
The TL-WDR3600 features Wi-Fi Protected Setup™ (WPS) that allows users to almost instantly setup their security simply by pressing the "WPS" button automatically establishing a WPA2 secure connection, which is more security compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
Easy to Use
The device comes with a CD featuring an Easy Setup Assistant that leads users through the setup process step-by-step, and even helps with wireless network settings and security configurations. With setups this easy, even novice users can have their networks up and running in mere minutes.
Header / Manufacturer
TP-LINK Technologies
Wireless router
Networking / Connectivity Technology
Wired, Wireless
Standards
IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Speed
600 Mbps
Miscellaneous / Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK
Networking / WAN Ports Qty
1
Aerial / Antenna Qty
2
Networking / Integrated Switch
4-port switch
Miscellaneous / Compliant Standards
CE, FCC, IC, RoHS
Connection Type
DSL (Cable)
Rackmount or External
External
Aerial / Aerial Form Factor (F)
External detachable
Environmental Parameters / Min Operating Temperature
Environmental Parameters / Max Operating Temperature
Dimensions & Weight / Height
32.5mm
Dimensions & Weight / Width
243mm
Dimensions & Weight / Depth
160mm
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.62
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.63
£13.69
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.54
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£17.96
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Fixed My VoIP
Reviewed by Steve Jones on 25/08/2014
This is a very good piece of kit. My Sipgate VoIP phone kept going off line behind my Virgin router. It's as stable as a rock now, no problems at all. Nice and straight forward to configure. I've connected my 500GB usb disk to it to use as network storage and backup for my wife's laptop. It also works as a media server, which was useful as we have an RKM TV Box which happily finds the router. My one moan was I couln't get my linux web server to run through it, but I was trying to link the virgin DMZ to the TP-Link DMZ which is probably impossible. I just put it through the Virgin DMZ, it's not elegant, but it works.
3* Not as described
Reviewed by scotc on 15/02/2013
This router is NOT Linux compatible as stated. Everything works fine on Linux except the Print Server function which is non-existent. There are forum posts about this issue across the web. It's Tp-link's fault and they are making a false claim. Note that the information on the BT.com website is not FROM their website and they do not endorse or take responsibility for the erroneous claim. If you don't want a print server, then this router works fine. The signal strength didn't seem that much better than my old "g" router though.
2* Good but gone off TP-Link
Reviewed by Francis Wilson on 06/02/2015
Perfect for most peoples needs but dont expect too much, The Wireless is rubbish for range but ok if you not got very thick walls. Was very easy to setup just plug-in and play.
Value for money but overall product rating is 2.
Scroll to top
