BT.com
Wishlist
TP LINK AV500 Powerline AC Wi-Fi Kit
Delivery
Standard Due date unavailable
Based on the Powerline technology, your network extension is never limited to the primary coverage of your router. Using your existing electrical wiring, this kit brings network to anywhere there is a power outlet. You can easily create a dual-band Wi-Fi network (simultaneous use of 2.4 GHz and 5 GHz bands) with more bandwidth and less interference, maximizing the performance of your Powerline network. A unified network allows you to stay connected, even when you're on the go. You can enjoy a single, seamless network throughout your entire home or office, without having to switch from one hotspot to another.
What's in the box
  • TP-LINK TL-WPA4530 KIT AV500 Powerline ac Wi-Fi Kit
  • 2 x network cable - 2 m
  • TP-Link AV500 Powerline Adapter (TL-PA4020P)
  • Software
TP-Link TL-WPA4530 KIT AV500 Powerline ac Wi-Fi Kit - bridge - 802.11a/b/g/n/ac - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV), IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
500 Mbps
Routing Protocol
IGMPv2, IGMP, IGMPv3
128-bit encryption, VLAN support, Quality of Service (QoS), reset button, Type of Service (ToS)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 1901, IEEE 802.11ac
13.1 cm x 7.2 cm x 4.7 cm
Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
500 Mbps
Max Range Indoors
300 m
Routing Protocol
Encryption Algorithm
WPA, WPA2, 128-bit AES, WPA2-Enterprise, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 1901, IEEE 802.11ac, FCC, RoHS
Status Indicators
Power, WLAN, LAN
Line Properties
Line Coding Format
OFDM
3 x 10Base-T/100Base-TX - RJ-45
Internal power supply
8 Watt
Software Included
Drivers & Utilities
13.1 cm
7.2 cm
4.7 cm
10 - 90% (non-condensing)
Scroll to top
