Click to visit BT.com
BT.com
Wishlist
TP LINK AV200 Powerline Homeplug with Wireless N Access Point/ Range
Quicklinx: 85ZGWS00
Mfr#: TL-WPA271
TP-LINK Wireless N Powerline Extender TL-WPA271 extends the Internet connection to every room connected to a home's circuitry. All devices in the room have two options to get access to TL-WPA271, whether through wireless or using an Ethernet cable. With 200Mbps Powerline link rate and 150Mbps wireless N rate, it is ideal for bandwidth consuming or latency sensitive applications like video streaming, online gaming and Internet calls.
With TL-WPA271, Internet can now truly be available everywhere in your home or office.
Up to 200Mbps, 300 Meters
With advanced HomePlug AV technology, TL-WPA271 provides users with stable, high-speed data transfer rates of up to 200Mbps on a circuit length of up to 300 meters. Together with its built-in Qos and powerful AES encryption, the TL-WPA271 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles, to set-top boxes for IPTV, printers and NAS.
150Mbps Wireless N Rate--Extend Your Wireless Coverage
With wireless speeds of up to 150Mbps, users can effortlessly extend their networks via their home's existing electrical circuitry and broadcast a wireless signal to another area of their home or office.
Multiple HD Video Streams
With 200Mbps powerline and 150Mbps wireless speeds, the TL-WPA271 is ideal for lag-sensitive applications.
Pair Button for Easy Network Security
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection.
1. Plug the adapter into the power outlet
2. Connect the device via the network cable to the adapter
3. Press the encryption buttons--and you're done!
WPS One-Button Security
Compatible with Wi-Fi Protected Setup™ (WPS), TL-WPA271 features WPS One-Button Security Setup that allows users to almost instantly setup their security simply by pressing the "WPS" button on the adapter, automatically establishing a WPA2 secure connection, which is more secure than WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
Support QoS for Advanced Multiple-media Optimization
The device's Quality of Service (QoS) function prioritizes the bandwidth requirements of data traffic. Users can choose which type of traffic they will use -- Internet, Online Game, Audio, Video or VoIP and the QoS functions will guarantee clear, instant reproduction of that application, even when other applications are running on the network at the same time.
TP-LINK TL-WPA271 - bridge - 802.11b/g/n - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Data Transfer Rate
150 Mbps
Quality of Service (QoS), Wi-Fi Protected Setup (WPS), integrated power socket
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV
10.5 cm x 5.8 cm x 4 cm
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Data Transfer Rate
150 Mbps
Max Range Open Space
300 m
Encryption Algorithm
AES, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV , FCC, RoHS
Line Properties
Line Coding Format
OFDM
1 x HomePlug AV , 1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
6 Watt
1 x network cable
Software Included
Drivers & Utilities
10.5 cm
5.8 cm
4 cm
10 - 90% (non-condensing)
