BT.com
Wishlist
TP LINK AV1200 Passthrough Powerline Wi-Fi Kit
TP LINK AV1200 Passthrough...
£137.84
15 in stock
£137.84
Add to wishlist
Delivery
Standard 1-3 working days
Expand your Wi-Fi network using your home's existing powerlines. Plug in the TL-WPA8630P to transmit an Internet connection to any area in your home and share that connection with all of your favorite wired and wireless devices. A unified network keeps your connection stable, even as you move around the house.
TP-LINK TL-WPA8630P KIT - bridge - 802.11a/b/g/n/ac - wall-pluggable
Bridge - 3-port switch (integrated)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV) 2.0, IEEE 1901, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
Routing Protocol
IGMPv2, IGMP, IGMPv3
Quality of Service (QoS), 2T2R MIMO technology
IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV 2.0, IEEE 1901, IEEE 802.11ac
AC 220 V (50 Hz)
7.5 cm x 4.2 cm x 15.2 cm
Apple MacOS, Linux, Microsoft Windows Vista / XP / 7, Windows 8 / 8.1 / 10
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
Max Range Indoors
300 m
Routing Protocol
Encryption Algorithm
128-bit AES
IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV 2.0, IEEE 1901, IEEE 802.11ac, RoHS
Status Indicators
Power, WLAN, LAN
Line Properties
Line Coding Format
OFDM
LAN: 1 x HomePlug AV , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 220 V (50 Hz)
TP-Link TL-PA8010P
2 x network cable - 2 m
7.5 cm
4.2 cm
15.2 cm
10 - 90% (non-condensing)
Scroll to top
